This is actually for @ Geoff Crispin!! Have a look at the wiring as written by Brian and get out your digital tester! Then test each wire and series to make sure everything from the FOB is working correctly when you press the buttons individually. Check that there isn't an abnormal draw anywhere which could lead you to your problem! Sorry for the intrusion gents!! JIMBrian,
quick question - thanks for the wiring sheet.
my central locks were not working - the 25A fuse was blown. Replaced the fuse, put the key in and turned the lock - fuse blown.
given things i read on this site - i suspected an issue in the boot, so i checked the wiring , after that i tried to eliminate components -
so i checked the actual latch - it has a plug in it with a blue/ grey and a white - when i disconnect and replace the fuse, leaving that unpliged all works -
this car has had some rear damage repaired by a previous owner and i am thinking somehow this plug goes to the actuator and not the latch itself - could that be the issue?
thanks!
Tom
Had an annoying squeak in the rear right of my Z3, just over my right shoulder (Drivers side right hand drive). Turned out to be a worn top mount when they were changed.OK- so the previous owner who fixed the wire harness did indeed reverse the wiring - plug on the actuator was actually on the latch - so when a signal was sent - direct ground, fuse blown.. 10 minute fix and all is good!
thanks everyone for the input.
now on to that mysterious squeak/rattle in the right rear!
Regards
Tom
Jim Mine is still not sorted, with key sometimes all locks work but mostly just a door and boot. With fob only boot locks and doors try to (you can see the push button move a bit). All boot wires seem ok after repairing two so my problem I think is in a door or doors.This is actually for @ Geoff Crispin!! Have a look at the wiring as written by Brian and get out your digital tester! Then test each wire and series to make sure everything from the FOB is working correctly when you press the buttons individually. Check that there isn't an abnormal draw anywhere which could lead you to your problem! Sorry for the intrusion gents!! JIM
