Yes, the inlet was a bit of a fiddle. I suspect we are looking at about 10 minutes for the exhaust sensor
Good read.
I too have the 2.2, and came to it from my daily driver that has 420hp. It felt very poor initially, but a can of BG44K, Shell Vpower every fill up and a K&N drop in filter have made a great difference. Also, reset the Drive-by-Wire throttle adaptations:
1. Turn ignition ON (KL15) for 10 seconds. DO NOT ATTEMPT TO CRANK / START THE
ENGINE.
2. Turn the ignition OFF for 10 seconds.
3. Start the engine.
It's certainly quick enough to get you in trouble, but it's not going to trouble my M car any time soon!
Great write up. I enjoyed the read. Really brave going on holiday in an unproven car, but I guess that's half the adventure.
Yes it's certainly getting thereGreat piece!
Sounds like you've got a great car now!
Welcome from Canada and glad tithe zed sorted itself out so you could enjoy Germany!! JIM
This thread may be an interesting read for you - https://zroadster.org/threads/terraclean-process.8362/I'm planning to have the engine 'Terracleaned' ...has anyone tried this?
Interesting Thread...I've also had Cata-clean recommended via the Jaguar Enthusiasts Club which is getting good reviews so may take that route first (well it is c.£90 less expensive so worth a pop!)This thread may be an interesting read for you - https://zroadster.org/threads/terraclean-process.8362/
You know, there's a good chance it could be. Pads and discs replaced about 2500 miles ago here so i will be stripping these today (or it could be desperation setting in!)It's the near side front![]()
The handbrake shoes in the drum part of the disc can come loose, this causes the shoes to rest against the disc and squeal, apply a little pressure to the handbrake when they are squealing and see if it stops?
Good call Tony, hoses should be delivered by the weekend so will go on....sledgehammer and walnut approach going on hereI would also check the rear brake hoses of being pinched by grips or even clamps, this could have damaged the internal wall of the hose preventing full release of brake pressure, which in turn will heat the brake and cause squeal. Just a thought.
