So after seeing Sean's nightmare with his sills I have been promising myself thats the job for this year, I was joined byJackdaw who came and gave a hand cheers bud much appreciated photo's as below tells the story so far.
Everything looks OK even being taken into FARMYARDS (David)
Most of the bolts were OK to take out but this one was a real pig had to cut a slot in the head then used a large screwdriver.
Photo below front a build up of muck not to bad considering thats taken 21 years
below muck removed still no signs of rust
rear very little muck still no rust
Outer sill removed ah there it is but a very happy bunny realy
so decided to use Vactan all you need to do is paint it on and when dried paint over whatever you feel like using, not like some other rust treatments that you have to clean of afterwards
this is just one application and have now applied a 2nd coat to the missed parts as well
I used Vactan on the inner sills as well, I also decided to treat the cavities on the inner sills with dynnax s-50
so all in all a very busy but good day 21 years old and that was all I could find lets hope the other side is the same, once again thanks Jack
