Could be a bent drive shaft Dave, probably on the back wheels. Check by jacking the rear up, put axle stands underneath to support it, crawl underneath so you can see the drive shafts either side of the diff, then get Jue to rotate the wheel. If the driveshaft is bent you should see it.
Mike
Mike
