Anything over 120Nm and the stick twists part way along instead, which absorbs the extra force, rather than transferring it to the bolt
Clean as much rust off as you can, use acid etch primer first as this will bind to the steel, prime and paint, let cure and rebuildAs it looks like I need to order more parts, in the meantime I reckon I'll tackle some bits of surface rust around the top mount holes:
View attachment 95337 Am I right in thinking that paint shouldn't be applied on the mating surface for a nut or bolt? So in the case of the photo above, I should clean it up and then do final primer/paint when the new shocks/topmounts are reinstalled and I can paint around the nut?
@Sean d and @mrscalex - your inputs would be greatly appreciated here![]()
Cheers mate. So after I remove the rust, it's fine to paint over the whole area including the lighter ring? It looks like it's had paint in the past to be fair.Clean as much rust off as you can, use acid etch primer first as this will bind to the steel, prime and paint, let cure and rebuild
More darty and planted, less body movement all round, and hugely improved braking. And all in the snowy conditions we've currently got in Newcastle. I imagine the difference in dry performance will be even tastier.
:Just to update on this. Finally got the new shocks on and torqued up today and took it for a test drive. My god, it's like a different carMore darty and planted, less body movement all round, and hugely improved braking. And all in the snowy conditions we've currently got in Newcastle. I imagine the difference in dry performance will be even tastier.
I pretty much replaced everything apart from the covers under the bump stops. I do like a picture of lots of genuine replacement parts in one place, something about the barcodes I think:
View attachment 95845 Compressing the springs was a nightmare. Like, a proper clusterf*ck. If I was doing it again I'd seriously consider taking it to a garage. But got it done and have the satisfaction of doing the whole job myself. Managed to scratch the springs and shocks in a few places so touched up using a Topaz blue pen. I had black epoxy primer left over from my sill job but couldn't be bothered mixing it up. Managed to sufficiently squeeze the springs using a combination of a friends' spring compressors, another set I bought myself, and some ratchet straps to help grab the last coil:
Tightening the top nut was also challenging. I don't have pass through sockets and didn't fancy dropping £50 on a set. I ended up buying a deep 22mm socket from Halfords for £7 and using my angle grinder to cut a slot in it for the Allen key:
View attachment 95846 This was enough to get the nut onto the strut, but after a certain point the top of the slot that I'd cut started fouling the Allen key which meant the top nut couldn't be turned any more. So out came the angle grinder again:
View attachment 95848 This was enough to get the job done and everything is back to normal now, apart from a brake warning light I have to knock out. I suspect this is because I started the car whilst the sensor was disconnected in order to turn the wheels and get a better angle for torqueing up the lower strut bolts.[/QUOTE
If you find you need a pad wear wire I have 3 spare ones on the shelf. Sounds like you had a fair workout doing those front springs Doc. for the top nuts I use an impact wrench (electric). Hope the snow soon disappears for this winter then you'll get to see what an improvement you have got
