Well doneOrdered everything I needed this week and will be fitting this weekend:
2x front springs and 2x front dampers (which altogether cost the same as one BMW damper!); upper and lower spring pads; and impact gun and sockets (not strictly necessary, but will prob make things easier/quicker and no doubt be useful in future)
Have ratchet straps arriving tomo morning which I’ll use in conjunction with spring compressors I’ve borrowed, because I don’t want to take any chances with that part of the process
There are some other small parts you may reflect you would want to change when you are in there. Numbers in brackets refer to diagram labelling:
http://www.realoem.com/bmw/enUS/showparts?id=CN12-EUR-02-2001-Z3-BMW-Z3_22i&diagId=31_0209
- (1) Top mount. Good practice to change these unless you know they are quite new
- (10) The rubber bump stop - often nasty buy not cheap
- (11) The dust sleeve - usually alright and not cheap
- (8) The top plate. These are nearly always rusty. It's not worth cleaning them up. New ones are cheap
- (13) A paper gasket which sits between the top plate and the underside of the inner wing.
Also note the Monroe top nut is a non-standard size if you are going to torque up with a pass-through socket.
If you have any issues (some aspects are a bit frustrating using spring clamps) I will happily work through it with you using my floor standing hydraulic spring compressor if you want. But it depends where you are as I'm in Swindon.
If you don't understand any of the above now don't worry. You'll understand it by the time you've sworn at it 200 times and lost most of the skin off your knuckles
Oh well, back to the dealer tomorrow then
. Anyways, it showed a spring compressor letting go at head height cos the car was on posts. The spring shot out between the two guys working in the wheel arch and it was a miracle neither was seriously injured. To be fair, they seemed like a pair of absolute numpties but it still put the jeebies up me. It was then I did a bit of googling on safety and saw guys on Pistonheads had used ratchet straps, which seem a sensible back up to use alongside the spring compressors. The ratchet straps might also mitigate the compressors trying to move around the coil?
