Hi everyone,
Hope everyone is ok i havent visited the forum in a while.
I was changing my exhaust in my 1.9 z3, the middle part with the catalytic converter. It was broken inside and was rattling a lot.
I managed to break the studs because the nuts were practicaly welded from the rust and removed the manifold.
Using the 2 nut method i removed one stud, the other one i hammered it out after some heat.
Then i am stuck with the two in the picture. Been fighting them for more than a month now.
Today i cut them, drilled them and then all my bits and discs broke. I even tried cutting from the side but nothing.
I dont expect to get them out without cutting the manifold from the sides and even then i dont know how to clean them out of the hole.
I know people around here are 1000 times more experienced with things like that so if you have any advice please let me know i really appreciate it.
I was also thinking what if i dont use them, will the middle ones have enough pressure with the gasket to seal the gaps?
