Steves Z3 engine swap
Was about to suggest that Stuart.
Bigwinn
Lincoln UK
Z4 3.0i
I think we are there
battery just on charge
found the right hole for the rubber pipe
Sorted the connectors
Bled the pas
Put water in and oil
Reconnected exhaust
All intake hoses back on
so now we wait for the battery to see if she fires up
eeek
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Good work, and it hasn't taken you long to do it either considering your working conditions
Bigwinn
Lincoln UK
Z4 3.0i
Just been out to start it- just a click
will recheck starter connections in am
Check engine earth before doing anything Stuart. If the main earth between engine and chassis is loose, or worse missing, you could fry something. Attaching a good size jump lead between engine block and chassis would elliminate the possibility.
Bigwinn
Lincoln UK
Z4 3.0i
Thanks Tony will do
I remember tightening it well but will recheck
Nice looking car is that Stuart.
Bigwinn
Lincoln UK
Z4 3.0i
On another note- how much of a PITA is it to coolant bleed an M52 engine…!
Slightly less than the 1.9 engines I think.
Bigwinn
Lincoln UK
Z4 3.0i
Read the codes today- only a couple and they are persistent?
many pointers?
Bigwinn
Lincoln UK
Z4 3.0i
Resolved
the plugs into each sensor were the in the wrong holes
how dumb am I to assume bmw made every plug different to prevent this
mental note for future to label all plugs
  • Like
Reactions: Lee
What was the fault with the number plate Stuart?
