Good spotting. Are there any special tools needed to redo the timing if you decide to take it apart?
Thanks Tony compare to what info I have and what I can currently see on the car itself .Have "aquired" the book Steve will post info tonight.
Update.....
Here's a little update on this .
Bought a new cam sensor while fitting and having top half of inlet manifold off looked over all the breathers again ( all look ok) so fitted sensor but unfortunately no major improvement so once again double checked all round the breathers and manifold ( checked with carb cleaner on cold engine to reduce fire risk ) but nothing obviously wrong.
That was a couple of weeks ago.
It's still light for a bit once I get in from work so decided to get into it again and check the timing next ( one of it's previous invoice for work to breathers and timing casing seals)
So off came the rocker cover engine set to TDC ( various paint marks on sprocket etc but expected to be as it had been apart)
On first look all seemed to be well View attachment 77531But on closer inspection I found something that is not quite right ( whether or not it will repair zed remains to be seen)
When the engine is at TDC the cams themselves appear to be in correct position it's the right hand sprocket that's wrong View attachment 77533on the left-hand exhaust sprocket the timing marker is vertical where it should be .
The right hand inlet sprocket also has a cam sensor plate on it .(it and the sprocket both have timing marker.
The cam plate mark is vertical but the sprocket mark quarter turn to the right.
Cam plate has an location knotch beside the timing marker and this is slightly bent as not correct positioned.
View attachment 77534 you can see the shiny bit on the rear of the sprocket where the pulley was covered by the camshaft.
So my thinking is that the cam sensor pick up plate may be a tiny bit out due to not being fitted to the sprocket in the right place .
So the plan is to take a bit further apart and putt if all back to the correct place and see if that sorts it .
Stephen.
Nothing conclusive yet Tony still need to do valve leak off test on head ( need to undo the cams so all the valves are shut 1st ) .Did you find anything as you stripped it Steve.?
