( 2.793 x 6800 x 60 / 2 ) x 0.0012929 = 736 kg / hr
620 / 736 = 84.2%
I'd be aiming for between 90% and 95% ( 660 - 700 kg / hr ).
Data for my test run (taken from the raw Testo data)...
( 3.201 x 7401 x 60 / 2 ) x 0.0012929 = 918 kg / hr
VE = 860 / 918 = 93.7%
I've heard that the S50 can be tuned to be higher than 100%, but that is race tuning, and would be almost impossible to drive on the roads.
The main problem with using data like this is that the sample timestamp for the rpm and the sample timestamp for the air flow rate CANNOT be the same, as data can only be snapped one item at a time, even though it is given the same timestamp. A lot can happen in a millisecond. Testo records 27 items every 200ms. There could be as much as 200ms between the rpm measurement and the air flow measurement. The crank will have turned 25 times in that time.
For example, here are the 6 consecutive datasets with full throttle...
Timestamp | Throttle Position | RPM | Air Mass |
13.8 | 98.4422 | 6557 | 782 |
14.0 | 98.4422 | 6720 | 786 |
14.2 | 98.4422 | 6887 | 804.5 |
14.4 | 98.4422 | 7072 | 822.75 |
14.6 | 98.4422 | 7246 | 840 |
14.7 | 98.4422 | 7401 | 860.5 |
This is why readings should only be trusted when the system is at steady state. An IC engine's parameters are constantly changing and there is never a steady state situation. The best that you can hope for is an ALMOST STEADY STATE. The problem with that is the readings for an engine running at a steady 7,000rpm will be different to the readings for an engine that is accelerating hard through 7,000rpm. It is the readings for the hard accelerating engine that we really want to measure, but we can't
