Bad news Duncan emailed the ebay guy reply was "it has the m54 engine instead of the m52 engine so this can't be done sorry" i will keep looking though and let you know what i findbruce&kim We need to talk I wonder if they would dod a deal for two at the same time? and what about the exhaust side, and is the throttle body bored out? Looks like a pair of good find though. The inlet manifold is about the righht price but there are some little bits and peices to make it fit right. I have a write up that I will email you, that I am still investigating.
Aceman I think you may be right. But I am not sure of the difference. The fly by wire does not have a cable I assume from the pedal which all the ones I am looking at do. But there is a whole load of references to electronic throttle control on the Z3 so is it a case that the cable operates something electronic? Or are the electronics on the throttle Separate? Anyway I hate the idea of leaving something up I am wrong about. So as far as I can see none of the Z3's I am looking at have fly by wire but they have a serious electronics around the throttle that does something.Learn something new everyday as I thought the fly by wire throttle came with the birth of the M54 I didn't think they did a 2.8 with this not in the Z3 at least.
