So who hasn't had the rear view mirror fall off? Wow, that many..
Ok, so for the ones that have had it fall off, what have you found to be the best product to stick it back on again?
I tried the pads and sticking just the fixing plate back to the window. When I came to twist the mirror back on though, becuase it is a pad, the pad just twisted with it and moved. If I use the pads again I would need to stick it up with the mirror attached.
I'm currently looking at the Loctite 319 but want to see what you can recommend. Thanks.
