Frank Redman
- Joined
- Jul 29, 2018
- Points
- 20
- Model of Z
- Z3
Hi Recently fitted Eiback pro springs. Rear camber needs adjusting. Is this possible or do I have to fit aftermarket adjustable bushes?
Thanks for reply.Sorry, no adjustment on OEM setup
Hi Thanks for the info. Will have a rethink on my next steps of the build. Great to see you in NZ. From a fellow Kiwi here in UkYou either fit adjustable trailing arm bushings which only give a small amount of adjustment or you weld in adjustment plates to the sub-frame which give you more adjustment. Either way the sub-frame has to come out.
Link to sample weld in plates mod
https://www.bimmerworld.com/Suspens...m-Camber-Toe-Adjustment-Kit-E30-Z3-318ti.html
