Prewashing
Z4 MR
Considering I don't have a hose or pressure washer (not that you can use them anyway at the moment) whats my best options for a prewash.
For the last couple of months I have been using a tip I picked up, which is to spray the car with a solution of car shampoo with a hand pumped pressure sprayer. This works really well and seems to help loosen the dirt (particularly the bird crap) before I go over with the wash mitt.
Are there any specific prewash products that would be more effective used this way?
Thanks SA. The first one is a little to extreme, but I may be able to borrow an elephant from Cotswold Wildlife Park.
Once again you have come up trumps! :(|)
Apprentice, the first one was rubbish, the second one ok.
Your standards are slipping.
i might need to step in and replace you :ymdevil:
without something to remove the worst of the dirt/grit without friction (ie hose / pressure washer) whatever you use will risk scratches.
You could throw buckets of water over it to pre wash but its been proven this uses massively more water than a hose pipe :-?
but buckets arnt banned :-o
I use a 5litre watering can to rinse the car off, so I know I use 25litres to rinse the car. It's ridiculously wasteful as a pressure washer probably wouldn't use a tenth of that!
Stick it under the shower, it has been scientifically proved that that uses much less water than putting it in the bath.
