Rebody Pingu's Kit Car Project
Pingu
Oh. Sorry. I take it back.
This video
At the start where the dash is picked up and flipped over it looks like light reflecting off screw heads. I just slowed it right down and see its rwflection off the corners of the demist slots.
Sorry.
So you used grp? Will that stick to the plastic dash?
No problem :) .
Yes - just roughen the plastic to create a key. I've found that fibreglass resin sticks to most things - hands, door knobs, kitchen worktops, Z3 dashboards... =))
Pond
Spaldingski, Lincs
No problem :) .
Good quality self-etching primer is also a good 'key' and saves a lot of hard work IME.
Pingu
Alternator failed on the way to le Mans last year. I think the cause may have been excessive under bonnet heat. I'm making a splitter to divert air around the radiator via a shroud. I think I will probably need some louvres on the bonnet to allow hot air to get out, but that can come later.
The dotted line shows air going through the shroud. The solid lines show the intended air flow.
It may help with air flow into the engine as the air filter entry is in this area as well.
Dxbolton
New Forest
2.8 auto
There should be a pipe to direct air up to the alternator from the lower valence on the Z3. Do you still have that pipe and can you adapt the lower end to get fresh air direct into the engine?
Pingu
I'll look on RealOEM. There isn't one on the ZM, but this ZM may be getting one. :thumbsup:
Many thanks for the info. There isn't one for my car, but there is one for the E30 M3. It has the same engine. I've ordered a used one from eBay, and I hope I can modify it to fit.
The part on eBay doesn't have the shroud over the rear of the alternator, but I kept the old alternator, so I can use that as a template.
My diagnosis of overheated alternator may well have been correct if there is already a solution in place.
mittaw
This is interesting as its something i was worried about...and planning a trip to Le Mans. Will be keen to hear if this solves your problem.
Pingu
The main shouding is fitted. I'm awaiting the shroud to the alternator, and that will mean a bit of stuff need to be taken off to see what I need to do - air filter, possibly air plenum
Main shroud comes off with three bolts. I'm just waiting for the Milliput to set, then I'll paint it satin black...
Oh, and I started the car :racecar: .
Runs sweet as a nut.
