No idea of what a Zener is, but you sound so scientific and full of confidence that I really think this will work. Good luck. (Googling Zener now).
I've spoken to ETB, and he confirms that its a characteristic of the clock. He thinks the Zener may work.Worth asking ETB about the drain. It does seem to draw too much, they may have a solution or there could be a fault with the clock.
Could you not get a rechargeable battery which you charge when the ignition is on and run the clock from that - when off it just uses the battery for the clock (so 1 in your list but use a small rechargeable?)I've found the battery drain. It's the "Veglia" clock. 60mA. Doesn't seem very much, but there is already a 75mA background drain, so the extra 60mA makes it an excessive 130mA. That's enough to drain the battery to about 50% in a fortnight.
I've thought of several options
- A second battery
- A simple switch that I use to switch the clock on and off
- Get a clock that uses less current
- Connect the clock to the radio or the ignition circuits
- A set-up that switches off the power to the clock when the voltage drops below a certain level
- Not practical.
- If I forget to flip the switch to off, the battery will go flat.
- I would need to find one that I can butcher, and I would need to butcher the "Veglia" one.
- I would need to reset the clock EVERY time I use the car.
- This would be some sort of Zener diode set-up.
I'm going to go with option 5. I may need to use the Zener as the switch for a transistor, but I may get away with just using the Zener diode on its own. Wish me luck.![]()
Remove the power from the Veglia/ETB clock permanently. At least it will be correct twice a day!
No idea why i am laughing as mine also drains down in a couple of days if not run. I have not investigated the voltage drop yet but could be the clock (ETB/Veglia) or i also suspect the audio sub below the seat wired for power into the old electric seat wiring (i am going to remove this over the weekend and eBay it as I never listen to music anyway, the exhaust is glorious so why bother!).
Have fun.
.I use solar power battery "chargers" on cars I don't use frequently.
I also have Bluetooth battery monitors so I don't even have to open the boot.
IT IS the clock. The Zener diodes arrived today. I'm just about to go up stairs and start playing with my variable voltage supply. I may get distracted by my train set, though.
Looking at google tells me that it is much more than just sticking a Zener diode in series with the load.
I've just spent £15 getting together enough electronics to last me a few more years.
I could have bought a module for £5.50, but where's the fun in that?
DC 12V Battery Undervoltage Low Voltage Cut off Recovery Protection Module Board | eBay
Find many great new & used options and get the best deals for DC 12V Battery Undervoltage Low Voltage Cut off Recovery Protection Module Board at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
