When under the car refitting the front bumper, I noticed a slight oil leak from somewhere higher up. Closer investigation showed that it was from the head cover gasket. It was not bad enough to have caused a drip yet but I thought it would be worth fixing. I got a new gasket from Sopers and removed the head cover, the gasket set consists of a moulded rubber outer gasket and two moulded rubber inner gaskets which seal the spark plug tubes. I was surprised to find that the old gasket was completely hardened, obviously the result of 101,000 miles of hot engine. The plug tube gaskets were rock hard and starting to break up.
This is obviously worth checking on higher mileage engines as, if left the oil will eventually leak into the plug tubes and cause problems.
A wobbly extension has the square drive ground down along its length to a more diamond shape which allows you to drive away from the perpendicular.
