obd2 location. I just bought a 1996 z3 that has a check engine light on. I can't find the obd2 port. Can anyone tell me its location? Thanks, FRANKIE
Z3's only came fitted with OBD2 sockets in late '98 where it was placed just underneath the stearing wheel. All the Z3's prior to this were fitted with a round OBD socket under the bonnet which has a screw off protective cap on it. Most diagnostic tools can still read from this soxket but an adapter will be required to connect to it. There are however better scanners than others as some are specifically suited to BMW cars and can read certain things other more generic scanners
Can't do. The best scanners are PC based like Carsoft and INPA which if you do a search there is plenty of info on here.
Thanks for the reply, Brian. I have an OBD2 scanner. Other replies have told me that my car only connects with a round connection under the hood. They specified particular types of scanners that I'll have to lool for. FrankieHi FRANKIE,
Such an early z3 will not have an OBDII port, you will only find a OBD port under the bonnet.
HTH
Brian
@FRANKIE, yes you can only use the round OBD port under the bonnet, I use BM Technic software on my laptop with a choice of either a usb - OBD (round style connector) or OBDII connector. Other member have scanning reset tools hopefully they will be along to advise.Thanks for the reply, Brian. I have an OBD2 scanner. Other replies have told me that my car only connects with a round connection under the hood. They specified particular types of scanners that I'll have to lool for. Frankie
