"Here's a little job!" my old boss used to say, well, as a rental home owner there is always a little job, . . . . . or 10.
Change water filter in the fridge,
thankfully easy enough to get to and you don't need to turn the water supply off (like our Samsung one at home). Run off 15 gallons!!
Next was remote control battery replacement,
Quite a few as you can see,
5 bedrooms with TV and satellite box and lounge, 2 master bedrooms have remote controlled ceiling fans.
Eleven smoke detectors around the house too.
This "wall art" acquired some lights last Christmas time so it needed 4 x AAs too.
One bulb out over the dining table, so 5 new ones fitted. If one has gone the others won't be far behind.
Then there's this!
For use out in 94 deg.
To rake off these coloured cobbles, lay some membrane, rinse stones and replace. Looking forwards to that.
ps. I may need a couple of those cold Coronas in the fridge after that.
