Did it come off easy Ian? Just some gentle heat?The M badge is gone! No more threats from the M-police for me!!!
As I don't have the 3.0SI badges on the wings I'm wondering if I should stay completely de-badged?
Yes - fairly easily. Hairdryer to heat it then a wide panel removed tool levered against a credit card. Bit more heat in the gap and gently eased it off. Didn't have a brake cleaner but used some lubricant for the clay bar and that eased the remaining glue and foam off.Did it come off easy Ian? Just some gentle heat?
but sounds like the attention has turned on to @Andy McDonnell
That phrase has been kicking around for as long as I can remember... Pre dates this forum by many many years!who started the "///M Police" ??
I did wonder what you were doing with my hair dryer....because you don't have enough hair to dry!!!![]()
Never thought of that.Dental floss or fishing line is kinder to the body work, you warm the sticky stuff and then saw through it.
Hair is overrated, or it will be once my solar panel gets bigger and the lot has to go.
Braided fishing line would do it as it's the same consistency as dental floss. Mono-filament nylon line would be useless as the heat generated by a sawing motion would cause it to break easily.Dental floss or fishing line is kinder to the body work, you warm the sticky stuff and then saw through it.
Have you tried using your credit card lately Gail?? JIMI did wonder what you were doing with my hair dryer....because you don't have enough hair to dry!!!![]()
