what purpose does the cross structure ( labeled E in the picture) serve
ok so is it worth it?Provides extra bracing betrween the suspension turrets and stops any flexing of the body tub at the front firming up the handling of the car.
No, bling.ok so is it worth it?
Did you see the original pic? It a device that's fitted under the bonnet. Nothing to do with the hood.And I thought they were there to hold your hood liner up..![]()
I was just joking hey, should have typed bonnet liner and not hood liner, under the hood here means under the bonnet usually. in the same way boot and trunk are interchangeable. However "Strut Brace" theory is that they prevent flex and improve handling as a result, I can see how some flex would be minimized if present, however stiffening one strut off the other one does not stop both from flexing together as was my case with a 79 mustang I had to fit one to many years ago now, because I kinda overpowered it, as you do. Under acceleration the torque was trying to tear the front of car off. I made it myself, and it made F$#% all difference, until I tied it back to the firewall in a big truncated triangle , and that only made a small but noticeable difference. and thus started the journey of chasing back the weak spots, all the way to and including the diff. but that's another story. Mexican gearboxes, yee ha...Did you see the original pic? It a device that's fitted under the bonnet. Nothing to do with the hood.
I'm Australian, lived here in England for over 30 years now. I've never heard the bonnet of a car referred to as "hood" before, unless you've all become Americanised in the last 30 years.under the hood here means under the bonnet usually
You've never heard the phrase, Let's look under the hood, or what have you got under the hood, ?. Could be a Kiwi thing though, I lived there for 30 years or so.. And yes Americanized we are becoming I think.I'm Australian, lived here in England for over 30 years now. I've never heard the bonnet of a car referred to as "hood" before, unless you've all become Americanised in the last 30 years.
Yes! My first Z3 didn't drive as well as I assumed it should, consulted various sources and the consensus was it would help. Fitted a brace and things felt better. It then went in for it's next MOT and they found some worn out front suspension components (ball joint and shock if I recall). When they carried out the work I asked them to leave the brace off and the darned thing drove spot on without it.actually have any experience of driving a Z3 back-to-back with a strut brace fitted and standard?
E85 have them too.Daughter in-law's old E87 BMW 120D has one from each strut to middle of chassis. Standard fitment as far as I know, so maybe the E87 was a bit wobbly ?
