new member "Hello"
2.2 Sport Individual
Hi @ANDREW HUGHES, :welcome: to the forum from me too in Staffordshire. Enjoy your project :thumbsup:
ANDREW HUGHES
sutton coldfield
2.0 6 cylinder
Ok
door handle rubbers - on order
aerial grommit - delivered (this weekend job)
Aerial arrived - dont know if I can get thread of old aerial out of the boot unit ? - any thoughts well received ?
rear wheel hubcentric spacers 20mm - because I think they just look better slightly wider in arches
(do I place some sort of anti corrosion paste between wheel and spacer and then spacer and wheel?)
Rear tyres can I get a less "flabby profile" of 225s ? or can i fit a narrower tyre ?
How 29
Rochdale
Z4 2.0 Edition Exclusive
welcome from me in Rochdale
:welcome: to the forum from Gloucestershire..
No I wouldn't, you shouldn't put anything between two machined parts that need to be absolutely true, just some on the hub flange that sits inside the wheel center. ;)
Ok
I always apply copper grease on the hub before fitting the hubcentric spacers. You may need to remove them at some point to change brake discs and if they get stuck it's very easy to break the thin centre which the wheel sits on. Two differing opinions, your choice;)
ANDREW HUGHES
sutton coldfield
2.0 6 cylinder
ok tried to replace aerial today
disaster
removed base unit and the top has been snapped off !
previous owner left aerial in boot now see ball type end is still attached to aerial !
plus lost my new grommet in wing !
so anyone got a base unit please ??
disaster
Try our resident breakers @spurs fan in a coupe or @Synclare they usually can arrange parts. :thumbsup:
FRANKIE
Hello everyone,
I have just purchased a 2000 Z3 2.0 6 cylinder.
Black nice condition, a few little dings and broken bits but with your forum I am going to work my way through them.
Looking forward to bringing her back up to scratch.
Welcome to the forum from Egg Harbor Township, New Jersey..............................Frankie
ANDREW HUGHES
sutton coldfield
2.0 6 cylinder
Hello all many thanks for all the hello from everyone and everywhere! Truly amazing
Work up date
Aerial base and grommet changes
( thanks to spurs fan )
Sent me base aerial and big grommet and an aerial too ! Big thanks
Dash odometer bulbs changes
Door handle gaskets changed
So far so good
Mr C
Many thanks
To do list
electric roof not working
drivers electric seat screeches forward fine going back slight rocking
aerial snapped off
two rear tyres required
buisness cd jumping
mileometer no longer lights up
an old nokia phone cradle and screen aerial to remove
drivers seat lumbar cracked and squashed
wing mirror bases paint bubbling
internal paint on roof aluminium corners peeling passenger side
gear box oil change (if people think it is worth it)
rear bushes to be changed maybe dont know yet (again if people think it is worth it?)
and anything else along the way I find
jobs done
gear knob replaced
found cigarette lighter under seat
blanking plate for rear roof switch not used found
windscreen wipers replaced
oil change done
brake pipes checked all ok
rear screen cleaned a lot better
so some work to go at ......but she looks great .....sounds great .....and drives great
I know it may be obvious but you do know that you have to put your foot on the brake for the roof to work ? I had a dealer make that mistake
roadvoyager1
Shotley Bridge
2.8ltr
Belated hello and welcome from me. You seem to be making steady progress through your list of jobs.
A couple of questions you asked early on. Change gearbox oil? Yes and diff. oil. The BMW "for life" did not anticipate it being 20 years on and still going strong. Plenty of posts on here regarding correct oil specification to use, or get in touch with Opie oils for their recommendation. Also rear beam bushes replace? Again - Yes! Due to the age of our cars most of the rubber parts have deteriorated, so check all of the rubber bushes on your suspension (www.realoem.com is really useful). Have a look at the Zshed posts also to get an understanding of what is involved. Then there is the question of whether to polybush or not?
Welcome to the world of Z3 and empty wallet syndrome. We can always find ways to spend your money......by the way if you are doing bushesyou might as well look at suspension dampers, mounts and springs.
Enjoy!!
ANDREW HUGHES
sutton coldfield
2.0 6 cylinder
many thanks will be getting gear box oil changed.
tried everything I can on roof.
checked wiring loom in boot a few cracked wires which I have covered with tape for now but nothing obviously broken that I can see all cables exposed from loom of doom and look good and flexible
followed the method of open and closed and it doesnt work
probably now need assistance - I get nothing no noises or obvious sounds
micro switch sounds and feels ok
so unknown fault
checked fuse all looks ok
stumped
