Well it's not washed away despite the rain we had last Wednesday night which flooded the front garden and almost came up the steps through the front door. No leaks in the garage though
Following on from the last post, all the electrics are now in and working. 4 double sockets along the back.
A couple either side. Plus a couple of breaker ones either side at the front not pictured.
Outside socket on the rear.
Indoors we have the consumer unit and some relays hidden away to control the lighting. I have a 'sonoff' unit which allows it all to be controlled via an app, or Alexa. I also have a scene set up so when the door opens the lights come on or when the door closes the lights go off. The patio lights also have this option and are set up on a timer. I can override all lighting with the wall switch incase I want the door open and lights off (daytime) or door closed and lights on (evenings etc). The standard light switch is on the left, which is also where the door controls will sit and the sonoff unit on the right meaning I have controls for everything either side if I'm not using the app or I can't be arsed to walk to the opposite side of the garage
Temporary lighting hung in place, 3 units in total. These will probably get changed next year for slimmer units.
It's all been painted up outside with some Ronseal which didn't do what it said on the tin! Apparently 3 coats were needed on newly planed timber, it took 6. And the trims finished in white for a bit of contrast. I trimmed the finial down and angled the edges.
Plus a little update on the garden, got the slabs for the rear pathway to the back of the garage down and a couple behind the garage for the bins to go on. The slabs on the pathway were the closest match I could get to the old ones without paying £10 more per slab. They are supposed to be grey but don't look it so hopefully after it's all been cleaned it may match a bit better. The 2 for under the bins are just some plain old things.
The gravel has been put down between the driveway and garage, looks great now and no more mud pit. We also put some log roll down the side as some of the fence panels are higher and the gravel boards are held in with bricks. This just covers the area and we will fill the gap with something to neaten it up. I made a fence panel to cover the gap between garage and fence panels to stop the dog sneaking down there and winding next doors dog up
A couple of pics of the outside lighting at night.
And the inside lights at night.
My poor zed hasn't been parked in a garage since November last year. Guess what, it fits
The door should be here next Monday so hopefully next week it will be a proper garage! Still got to paint the floor, I put another 2 coats of sealant on it earlier as I had some left. And then a few odd jobs on the garden to complete.
