WK02RDJ BMW Z3
Check another vehicle
Colour Yellow
Fuel type Petrol
Date registered 28 May 2002
MOT valid until 11 September 2018
Get an MOT reminderwhen the vehicle's MOT is near its time for renewal. (Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong,
contact DVSA.
Check mileage recorded at test, MOT expiry date, defects and advisories
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor.
Find out more
Date tested 8 September 2017
Pass
Mileage 60,170 miles
MOT test number 2914 6640 1256
Test location
► View test location
Enter latest V5C number11 digits from the vehicle log book
Expiry date 11 September 2018
Advisory notice item(s)
- Nearside Rear Subframe mounting prescribed area is corroded but not considered excessive (2.4.A.3)
- Offside Rear Subframe mounting prescribed area is corroded but not considered excessive (2.4.A.3)
- corrosion front and rear jacking points
- surface corrosion front and rear suspension
- engine cover fitted covering testable items
► What are advisories?
Advisory items are provided for advice. For some of these, if they became more serious, your vehicle may no longer be roadworthy and could require immediate attention.
Date tested 12 September 2016
Pass
Mileage 60,132 miles
MOT test number 6698 9803 7644
Test location
Expiry date 11 September 2017
- Offside Front Lower Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
- Nearside Front Upper Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
- Nearside Rear Outer Brake hose has slight corrosion to ferrules (3.6.B.4e)
- Offside Rear Outer Brake hose has slight corrosion to ferrules (3.6.B.4e)
- both rear tyres tread cracking on inside edges
- Offside Rear tyre had cut in tyre, ply or cords not exposed
Date tested 9 September 2016
Fail
Mileage 60,131 miles
MOT test number 3524 5808 3547
Test location
Reason(s) for failure
- Supplementary Restraint System warning lamp indicates a fault (5.4.2)
► What are failures and advisories?
Failure items must be fixed before the vehicle can pass its MOT.
Date tested 10 September 2015
Pass
Mileage 59,676 miles
MOT test number 4002 7384 2770
Test location
Expiry date 9 September 2016
- Front exhaust flanges corroded
- Slight play in steering rack
- Underside of vehicle has been undersealed
Fail
MOT test number 7667 4314 7515
Test location
- Offside Front Direction indicator incorrect colour (1.4.A.2f)
- Offside Side repeater incorrect colour (1.4.A.2f)
- Offside Registration plate lamp not working (1.1.C.1d)
Date tested 29 July 2015
Fail
Mileage 59,658 miles
MOT test number 5369 2071 5200
Test location
- Front Headlamp cleaning device inoperative (1.7.2)
- Nearside Front Trailing arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
- Offside Front Trailing arm rubber bush deteriorated resulting in excessive movement (2.4.G.2)
- Centre Rear Fuel pipe excessively damaged (7.2.2)
- Offside Rear Trailing arm corroded and seriously weakened (2.4.G.1) Dangerous
- Nearside Front Headlamp deteriorated but light output not reduced (1.7.5a)
- Offside Front Headlamp deteriorated but light output not reduced (1.7.5a)
- Nearside Front Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
- Nearside Front Brake hose slightly deteriorated (3.6.B.4d)
- Offside Front Brake hose slightly deteriorated (3.6.B.4d)
- Front Power steering pipe(s) or hose(s) slightly corroded (2.3.2)
- Nearside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
- Offside Rear brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
- Nearside Rear Trailing arm corroded but not seriously weakened (2.4.G.1)
- Nearside Rear Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
- Offside Rear Anti-roll bar rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
- Rear Brake pipe slightly corroded (3.6.B.2c)
- Nearside Rear coil spring corroded (2.4.C.1b)
- Offside Rear coil spring corroded (2.4.C.1b)
- corrosion on nearside upper strut mount (under bonnet)
- corrosion on offside upper strut mount (under bonnet)
- Spare wheel carrier excessivly corroded
- Nearside control arm corroded
- offside control arm corroded
- Front Chassis has excessive corrosion
- Rear Chassis has excessive corrosion
- Nearside and Offside brake back plates corroded
- Nearside front suspension strut corroded
- Nearside rear suspension strut corroded
- offside front suspension strut corroded
- offside rear suspension strut corroded
- Fuel tank strap corroded
Dangerous The tester has considered a part of the vehicle to be so defective that it is dangerous to be driven on the road.
Date tested 12 September 2014
Fail
Mileage 59,584 miles
MOT test number 8476 4575 4222
Test location
- Supplementary Restraint System warning lamp indicates a fault (5.4.2) Dangerous
- Offside Front Headlamp cleaning device inoperative (1.7.2)
- Brakes imbalanced across an axle (3.7.B.5b) Dangerous
- Power steering pipe(s) or hose(s) slightly corroded (2.3.2)
- Nearside Front Trailing arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
- Offside Front Trailing arm rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
- Nearside Rear Anti-roll bar has slight play in a ball joint (2.4.G.2)
- Offside Rear Anti-roll bar has slight play in a pin/bush (2.4.G.2)
- Body has slight corrosion (6.1.B.2)
- Fuel Tank Strap corroded
- Both front drop link bushes worn
- Exhaust system joints corroded
- Fuel pipes (underside) corroded
- Spare wheel carrier corroded and holed
- outer sills underside corroding
Date tested 10 September 2013
Pass
Mileage 58,336 miles
MOT test number 4954 1315 3216
Test location
Expiry date 22 September 2014
- Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d)
- Nearside Rear Anti-roll bar linkage rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
- Offside Rear Anti-roll bar linkage rubber bush deteriorated but not resulting in excessive movement (2.4.G.2)
- Nearside Front Shock absorber has slight corrosion to the casing (2.7.2a)
- Offside Front Shock absorber has slight corrosion to the casing (2.7.2a)
- fuel lines very corroded
- brake pipes slightly corroded in places
- exhaust deteriorated
- n/s front brake slightly grabbing
Date tested 9 September 2013
Fail
Mileage 58,332 miles
MOT test number 2557 7275 3207
Test location
- Fuel cap/sealing device sealing washer deteriorated (7.2.4c)
- Nearside Front position lamp(s) not working (1.1.A.3b)
- Nearside Rear Brake pipe inadequately supported (3.6.B.1)
Date tested 13 September 2012
Pass
Mileage 54,945 miles
MOT test number 9494 2705 2280
Test location
Expiry date 22 September 2013
- Windscreen has damage to an area less than a 10mm circle within zone 'A' (8.3.1a)
- underside of vehical and suspension has lots of light surface rust.
- pas pipe work rusty
Date tested 7 September 2012
Fail
Mileage 54,884 miles
MOT test number 3571 7115 2271
Test location
- Nearside Rear Brake cable has restricted free movement (3.5.1k)
- Offside Outer Front Direction indicator incorrect colour (1.4.A.2f)
- rear brake discs rusty
