Got an early finish at work today as the joiner and plasterer were where I needed to be
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
So with my new Powerflex diff mount bush gathering dust in the shed thought I'd have a go at fitting it
![Nail Biting :nailbiting: :nailbiting:](/styles/default/xenforo/smilies/nailbiting.png)
Got the rear of the car jacked up on the diff,axel stands under the sills but left the jack taking the weight of the diff to aid removal of the mounting
bolt......it's a bit tight under there with the original back box being huge.
But by jacking up the near side rear wheel the diff drops down a bit more and gives enough room to work
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The old bush took some getting out with some of it staying stuck to the metal ring,which was the next thing to remove after cutting a groove through it with a hack saw blade .......not easy when you're lying on your back under the car
![Hungover :hungover: :hungover:](/styles/default/xenforo/smilies/hungover.png)
The old one looked ok to me tbh till I wrecked it whilst removing
![Whistle :whistle: :whistle:](/assets/whistle.gif)
so old one out,new one in.....took about 3 hours on my own so not as bad as I thought it might be
I must say that if it wasn't for seeing how others on here had done it and being there when
@t-tony fitted
@Grumpy's with
@Antm72 at Zed Shed Midlands I most likely wouldn't have attempted it.......so thanks chaps
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Steve
