It is possible you may have got an incorrect read when you tested after the mod.
Also, as I and others have said, they get the impression of better power at higher rpm, but not at low rpm.
The BMW manifold and DISA system is designed to provide a modicum of forced induction by directing air volume towards specific pistons in greater than atmospheric pressure. This results in more HP.
With the larger M54 manifold DISA it is possible that this effect is increased and therefor a greater forced induction is the result.
Even using the OEM DISA / manifold setup, the DISA doesn't come into action under 3000 rpm.
My contention is that if the OEM manifold runners were to be engineered to the D shape of the cylinder head, it may result in similar gains as using an M54 manifold, with the exception of the larger DISA action.
If you still have your OEM manifold, it is a very easy bit of work to re-shape the runners to a D shape simply by using a rough square shape file to grind away the corners. In any event, the interior shape of both the OEM and M54 runners is oval and as on the M54 runners it flares out to the D shape. This means that it is only within 50mm of the mating points between runner and cylinder head that the differences occur.
Therefor it's the larger DISA flap which is making the difference at over 3000 rpm.
I have the M54 intake cam fitted. This has made the biggest difference in combination with the M54 manifold. the extra "open" time of the intake valves and also the higher lift it provides, allows airflow into the cylinder to be less restricted by the valve being opened wider and longer. The resultant power gain is significant. What remains for me to do is to have the fuel supply - ie the injector "open" time re-programmed to compensate for what is currently a "lean" mixture on my motor.
Obviously this will mean a higher fuel consumption, but a corresponding increase in power. I guess performance costs and costs and costs..
