- Joined
- Apr 27, 2012
- Points
- 100
So... after some research and pondering, I managed to pick up a 330i M54 B30 Manifold complete with guaranteed 100% working DISA valve fitted. ( £50 plus £20 courier costs). It should arrive on Wednesday and then I'll send it down the road to my engineering buddies for a good bath - (£10 ) which will clean out the interior of any oil or other foreign matter...
And finally an OEM manifold to cylinder head rubber gasket / seal - no cost available as yet.
Once I get it back I'll be doing the swap onto the M52TU motor. I've decided to have my own adapter plate made here vs paying £80 plus VAT and import duties (15% and 20% respectively)... I can have one cnc cut routed drilled and threaded for around £25 - 30.
Since I will already have the larger DISA already fitted, that will save me a heap. After that it's just my time and labour to do the swap, which I am already 90% up on having recently replaced CCV and fitted the Moroso oil / air separator catch can into the car.
For those who aren't aware, the M54 B30 manifold is a direct bolt onto the M52 head. The only modification required is to fit an adapter plate to enable the M52TU throttle body to be fitted to the M54 manifold. All else is a matter of connecting existing hoses wires etc etc back again.
So, why do this ? Well below are comparison pics of the inlet runners of the M52 and M54 manifolds. As you will see the M52 pipes are oval in spite of using the same manifold to head gasket as the M54 manifold. The head ports on the M52TU are "D" shaped - exactly as are the intake pipes on the M54 manifold. One has to wonder who at BMW had a rush of S... to the head when they fitted the oval pipe intake to "D" shaped cylinder head port...
So, with better intake airflow - less restrictive - the general consensus is that this will deliver around 15 - 20 ponies at the wheels - much the same as one would expect if we RHD Z3 owners could fit sports exhaust headers -(another issue I'm looking into)...
This is a relatively cheap modification which can be done by the home enthusiast.
I must add one important point here - The Turner Motor Sport adapter to do this mod is NOT a well conceived or thought out piece of equipment since it requires grinding away part of the OEM throttle body and even then, one is left with only being able to use 2 of the 4 bolts that hold the throttle body to the adapter.. Not very satisfactory.
There is a fella who has designed and supplies the "right" adapter for around $60 plus $ 20 shipping but excludes import and VAT costs... Hence me doing my own thing....
I guess it would have been cool to do a before and after on a dyno to have some substantiated results, but I really don't want the extra cost. I'll give my opinion on the results though..
In the attached pic you can see the M52 vs M54 inlet pipe shape and relative sizes. Also, a pic of the M52TU Cylinder head intake ports...
