M
M666BMG
Guest
Well done mate, hope to meet you one day.Right guys, the missus has calmed down, and i have now had two weeks to live with the car, no telemetry data yet, but just from driving i know it will be a lot different from standard.
Re-cap so what did I set out to do? I wanted a car that was responsive, that when i changed up or down gear the power came on like the opening of a tap, i wanted a smooth fast power delivery, i wanted a country lane barn stormer of my yester year (MK2 Escort, Pug 205 GTI).
So what did i get?
Well, little secret here, i mentioned early on that i also wanted a re-map, so i had that done while it was having the other mods and tweeks completed, heres what I have done:
Quite a lot done in the last twelve months now that i look at it, and the garage has now been converted back into my Gym.
- Overhauled the rear subframe, Standard beam bushes, powerflex swing arm bushes. painted.
- Overhauled the diff, new Redline 75W90 Hypoid gear oil (Diff whine has gone)
- New rear wheel bearings
- New ABS sensors
- New back plates
- New rear calipers and red stuff pads
- New rear flexi pipes
- New rear hard lines
- Brake fluid change
- New hand brake cables
- New fuel tank straps
- New water pump & thermostat
- New Auxilliary belt, belt tensioner and pulleys
- New HT leads and plugs - NGK BKR6EQUP
- Oil & Filter - Fuchs Titan Super Syn 5W40
- Gear box oil seal and shifter bearing change.
- New Gear Box oil - Red Line D4 ATF/Automatic Transmission Fluid
- Aluminium Lightened and balanced single mass fly wheel, clutch cover and Valeo clutch plate
- New Subwoofer enclosure
- Remap
- MOT - Passed
I also took the time to build the good lady the en-suite of her dreams.
So how does it drive i hear you say?
Well, it exceeded my expectations in all areas except one, come back to the latter.
The car now idles very smoothly, i did not expect this I expected it to be worse, there is no gear box chatter, other than when in neutral and then it is not noticeable.
The car is extremely smooth to drive, i actually manage to drive it better than a car with a DMF. Acceleration in first and second is really awesome, looking forward to the tele data.
The theory suggests that at the current weight of the fly wheel should be putting through to the wheels an extra 30bhp in first and 20 in second. This is not extra power generated, just existing power that no longer goes into turning the heavy DMF. I do not know what the actual figure is, but you can feel it and the power comes through right up to the redline without hesitation.
Driving on the twisties is fantastic, you have engine barking and instant power out of the corners, reminds me of my old MK2 Escort which had a similar setup. I have to say that I now get a smile every time i drive it, where as before it would sometimes leave me feeling a little bit Meh!.
So whats the down side?
The exhaust note has changed, it is fantastic from a standing start, but it now drones on a long 70mph journey and i don't like it, it did not do this before, and i don't understand why, but i will have to get it sorted.
Would i do it again?
If cost was no option the answer would be yes in a heart beat, I think this time it was an itch that needed scratching, it certainly demonstrated that you need a good work shop and tools. I have the tools, but lying on your back for hours with rusty nuts and bolts is not rewarding.
I have discussed this at length with the good lady, and I am in agreement, time to save for that Cobra or Porsche I've always wanted, so I am going to drive it now and enjoy it, it has been off the road for the majority of my 3 year ownership, as i keep scratching those itches, so I need to stop (Fingers Crossed).
I will post the tele data shortly, possibly over the xmas holidays.
