ask the indy first, no point spending on parts you don't need, luckily I have INPA and was able to watch what the lambda was doing before I swapped it out.
I do get a hit rich smell sometimes but it's not regular, could that have somwthijh to do with it?I wouldn't worry too much, think yours is a different problem, if you look through other BMW forums this is a very common trend with the M44, less so with a six pot, the six seems to age really well (unlike the M44) no one really has nailed it down yet.
how did it do while over at t tonys? I seem to recall something about it not getting up to temp (oil)I do get a hit rich smell sometimes but it's not regular, could that have somwthijh to do with it?
He couldn't get the co2 down on the mot either Jason.how did it do while over at t tonys? I seem to recall something about it not getting up to temp (oil)
Hope its something simple like that, but my indy checked the car before the cat was replaced for air leaks and said all was OK. I'm a bit stumped at present!Similar problems with my m44 with crazy readings. Problem with mine was an air leak causing the engine to run rich. Turns out the rubber tubing from the air mass sensor to the engine had some holes either end which would mess up the fuel to air mixture. Take the clamps off and check the areas directly underneath the clamps too. New part on ebay is £13.
Was just a thought that different fuel will burn slightly differently. If you’re close to or on the margin it could be sufficient to push emissions over.The M.O.T. emissions test is supposed to cover any commonly available fuels so I can't see that being an issue Ian.
ps. My suspicions are aimed at the heater element of the O2 sensor assuming it's a 4 wire connector.
You are right of course about getting what you pay for Tony, except I have effectively purchased three new cats in the last few weeks and only the OEM one worked. Fortunately, I had the funds to buy the OEM one but, as the cost was approaching the price of a reasonable Z3, others may struggle, hence the warning.Doesn't need to be type approved for older cars and this is how these companies can sell under sized shoddy crap which will usually outlast their warrant . . . . . just.
You get what you (or the previous owner) pay/paid for.
