Low mileage 9 year old water pump?
Smudgemanuk
Bicester, Oxford
2.8l
I have a 1998 z3 2.8
The water pump on it (according to service history) is 9 years old but has only done 4k miles
It is also most likely a plastic impeller one
Can I trust this water pump or should I replace it while I am doing other bits nearby?
Thanks Chris
Althulas
Banburyshire
M Roadster
Andyboy
SHEFFIELD
There is a lot of b*******s talked about plastic impeller pumps and how metal ones are better.
Sure, early ones had issues but that was 20+ years ago. I recently replaced the failed pump on a 2002 320i E46. The impeller was fine, the bearings were not. But it was date stamped 2001. How long are they supposed to last?
I've not seen a failed plastic impeller in 20 years.
The worst pumps are the ones with the iron impellers, so heavy the bearings won't last as long.
If it's a BMW pump it will be fine.
