yellowjacket
- Joined
- Oct 28, 2018
- Points
- 22
Hi folks - I've made some excellent progress rehabbing the Z (with help from you guys), but am stuck stuck stuck on the A-pillar issue. The right hand side is clogged and I can't seem to make any progress in unclogging it. I've searched high and low, and tried the following: soapy water, compressed air, plastic tube from from spray can. There's clearly something in there that doesn't want to budge. I'd tried a stiff wire, which worked somewhat, but also poked a tiny hole in the rubber. Please, voices of experience, share your wisdom!
