Nice additionsResult, the correct hoop has arrived. No offer of a postage refund, but I'm past caring....
Time to insert it where it belongs...
Looks great
(i know I have some of the base rubbers wrong, I fixed that before bolting them up)
Quick trial fit of the Tanneau cover....
And the wind deflector...
Time to sort these wheels...
15mm off...
Clean up the face...
30mm on...
And bolted up...
And pop the wheel on...
Oh, that's flush...
Roll it out of the garage...
After doing the same at the front and swapping my 3mm spacers for 10mm, that looks equally flush...View attachment 73282
Right, needed some garage space, so asked my dad to take it away for a while...
So, the wheels are on. They do look great, but I think I still prefer the Style 18's.
Think I might have to raise the rear or drop the front a few mm to get the rake just right, but will let the new springs settle in for a few weeks first...
At christmas I bought some seat heaters and 2 OEM switches. Going to put them up front and either relocate the Alarm flasher to the rear panel, or just hide it behind the dash if it's too much effort. Any tips???
When poking around in the rear switch panel area, I already have the rear winodw demister button, but also found a small 2 pin connector sitting loose. Anyone got an idea what that's for?
And, with spring approaching, it's almost time to flog some of the old stuff that's no longer required...
Any idea what the old wind deflector and mounts (below) go for?
Small but important details make all the difference.Well, it's been a few months since I last posted, but not much has happened.
After fitting the new coilovers, I left the car with my dad to hibernate over the winter, but in early March he needed the space so dropped it back off at mine.
The weather has been miserable so neither of us had much interest in taking it out so it's done a total of a bout 20 miles and still not had a setup done.
Anyway, about a month ago the sun popped out briefly and I had an excuse to go to the local shops so jumped in for a blast.
Awesome. This car is such fun, looks and sounds great and turns heads and grabs attention everywhere it goes.
Anyway, after the drive, I felt the rake angle was slightly off, and the rear left slightly imbalanced height wise so wanted to sort that. I also feel the 30mm spacers are too much for the Style 261's (49mm offset) when running so low. I reckon the tyre would rub if I rode a large bump so, some 25mm spacers were ordered. The 30mm would be fine with the 52mm offset 386M's. but I'm coming down with unused spacers and 25mm version will work fine with both sets.
I also took the chance on the sunny day to give the Style 18's and 386M's a good clean.
My only other tweak was to replace the bonnet catch which has always looked horrible.
View attachment 77928 View attachment 77929
Anyway, using photos for reference, I aligned the new catches in the same location and set the drop height roughly the same as what had come off. I also took some brake cleaner and used that to degrease the surrounding area before using some AutoGlym AquaWax to add some protection.
Btw, if anyone's looking to tidy up their current catches, leaving them overnight in Iron Fallout Remover works wonders, before giving them a dusting in paint to protect, but to be fair it was only a few quid for new ones.
On first close I could feel the catch was a little tight, so a quick adjustment sorted that and job done.
View attachment 77930 View attachment 77931
The new H&R 25mm spacers arrived a few days back, so next chance I get, I'll swap out the 30mm for a refund, unless anyone's looking a set?
So that's us up to date.
I've still to tackle the heated seats and rear axle bushes and keep dreaming of M50 manifolds and superchargers... Lets see what the summer brings....
Dirty thoughts....
Are 330 Sport brakes really big enough???
I guess they'll have to do.... when on 17's!
But on 18's.... there's room for some thing.
Oh, what are these get on my garage floor?
In all likelihood they'll end up on the 1er, but I'm wondering if anyone's fitted M Sport 4 pots up front on a Z3?
they've got to be too big surely, what size disc can they work with? if you could get brackets to work with 300mm disc i'd be super interested!
Well, it's that time of year where my dad clears off for a few months and I get the Z back.
Since the weathers been good, I've been mostly driving the M3 recently which is quick and solid. It's fully polybushed, coilovers, upgraded anti-roll bars, modified shifter and aside from some corrosion on the front wing, it's otherwise perfect. However, jumping into the Z for the first time in a while, it didn't feel quite as nippy, so I'll need to get that M50 manifold fitted up soon.
Anyway, before I get round to that I felt I needed a bit of housekeeping to the garage, so I've cleaned it out and swapped the old up-and-over door for a fancy electric roller.
The big advantage is that it'll add 8 inches to the opening width as I removed the old wooden mounting posts and it won't obscure my roof lights internally when open.
As for the old door, out with the biggest hammer I could find and batter it until it fits in the back of the Rav4!
View attachment 82996 View attachment 82997
Result.
Hope to get cracking on more Z upgrades shortly...
