Lewis' 2003 Sterling Grey 2.5 Z4 Roadster
Lewis Benson
Derbyshire
2003 e85 Z4 2.5
This seems a great idea - not only to share with others, but to keep track for myself!
I bought my Z4 in December 2025 and, having no history with it, gave it a full service including gearbox and differential oil changes.
I found the back end to be particularly twitchy, so replaced the old Michelin Pilot Sport 5s for some new ones.
That did improve things somewhat, but replacing the worn rear trailing arm bushes for some Powerflex ones and replacing the upper and low hub bushes improved the handling dramatically especially after I had a four-wheel alignment carried out.
Not long after, I had a couple of overheating issues; so had the water pump, drive belt, thermostat, radiator and expansion tank replaced which soon solved it.
Now it was driving perfectly, I could address cosmetic and not-so-important things like replacement badges, cup holders, aircon re-gas, boot struts, headlamp polish, wheel refurb and a sound generator.
Last month, I gave it another oil service and next month I plan on driving to Denmark (any suggestions on nice driving roads in Denmark would be appreciated!).
Things left to do:
  • The roof was a little lazy and, in an attempt to fix it, it now doesn't work at all!
  • Front bumper need respraying or replacing.
  • I would like red Sport seats when funds permit.
  • Replacement windscreen surround.
  • The NS electric mirror has stopped working.
I'm sure this list will change as time goes on, but that's it - that's my little Z4! Thanks for reading.
I would check the roof motor in the boot to see if it been subjected to water ingress.
This guide may be worth a read https://zroadster.org/threads/z4-roof-motor-relocation-to-boot.19256/
If that’s no use the Z4 forum has different post about your problem. For example https://z4-forum.com/threads/roof-motor-not-working-pump-failure-or-electrics.17692/
That’s about as far as I can suggest as I’ve never owned a Z4, maybe add a few more details of your symptoms to aid other readers such as door your roof light flash, windows drop, catches disengage.
Thank you for wanting to help @Althulas
I don't want to turn this into another "Roof Doesn't Work" thread, but the (already relocated motor) did work prior to my fiddling - it just needed a little assistance at the start when going down.
Now, however, the windows don't drop, the button lights don't illuminate and the parcel shelf switch is made (although I've not proved that it's still working).
I did actually get it working, but the next day it had stopped again!
This weekend:
For some reason, my sump cover was completely bowed a was scraping over speed bumps etc, so I removed it, cleaned it, heated it up and straightened it.
After an oil change mishap, I removed the undertray and cleaned it, the underside of the engine and gave the engine bay a good clean.
Finally, I have the whole car a good valet in preparation for a road trip next week.
