Sooo much better, I think the old components had been on there since new. Turns in nicely now, upgraded brakes, a refurbed subframe and some better tyres would suit it nicely. Oh, and then the wheel refurb!Great stance change - was looking good before but now ...
How does it drive ?
@ BMBabe is no longer blonde so you can't sneak things past her now!! JIMOops,sorry Martin didn't think Stacey would catch on to that one.
Roy.![]()
Thanks @Mnbrennan for that info. I have a 2.2 2001 so will need to look at if there is a different process.Hi Dave
As far as I'm aware there is no difference between the two in terms of diameter and thickness, it's just the design is different.
If your car is made before March 99 then it should have a single stage airbag. In that case it will be a straight swap, it's pretty easy to do.
1. Disconnect battery
2. Undo the two torx screws at the rear of the wheel, remove the airbag and disconnect the airbag (2x connectors)
3. Set wheel straight and remove the 16mm nut. The wheel will now come away
3. Remove the slip ring by undoing 3x torx screws on the rear of the steering wheel.
Putting the new wheel on is the opposite of removal
Yes you should have the dual stage airbag so would need to convert overThanks @Mnbrennan for that info. I have a 2.2 2001 so will need to look at if there is a different process.
I'm not sure why I like the older model so much
Dave
Yep, I do too, for some reason the newer model looks 'simple'.I'm not sure why I like the older model so much
Right up your street then . . . . . . . .Yep, I do too, for some reason the newer model looks 'simple'.
t**t....Right up your street then
You won't like mine then when they go Dakarall about the M Steering wheel, i'm not a massive fan of the blue bits personally... needs to be a bit more subtle
Actually I think yellow would workYou won't like mine then when they go Dakar![]()
