Front end refresh!
As posted above I ordered the following parts and we had a spare lift available today, so...
Also particularly helped with the fact that most of the Z4M front end is standard E46 parts bin making it really easy to find parts. This isn't a "how to" thread, just some random pics I took as we worked.
Before pics:
Wishbones look original, but then I'm sure everything we changed probably was as well.
New Meyle HD outer tie rods, ignore the drop links (I'll explain why they are wrong later)
The finish on Meyle HD parts like to coating on these inner tie rods is excellent.
Meyle HD wishbones
Removing the old rear wishbone bushes, simple case of hack saw through the rubber and out cut through the outer bush then punch out. Z4M bushes are unique due to the design of the solid rubber bush, non M are fluid filled.
The Powerflex bushes are a solid aluminium with a push in poly bush insert, also designed to give an extra .5degree +ve castor angle. Fitting these are not for the feint of heart and took way too much time a fettling. They are an interference fit and there is no tolerance, if anything possible fractionally oversize. We ended up reaming out the inner part of the holder with a flappy disc on a drill - taking care not to take too much material of. Even after this work it took a lot of patience and grease on the 12t press to align them. Utterly ridiculous but we got there eventually.
We got distracted at this point by the adults ice cream van turning up outside...
I only use Yellow Stuff pads, not used anything else for the last 5 years or so. Why fix what isn't broken!
These discs were more expensive than replacing front and rears on my old 3.0si including pads. But they look epic! Same discs as used on the M3 CSL.
Quick look underneath just before final tightening and checking over.
Then off to our local tame wheel alignment centre for a full 4 wheel alignment. Lee knows these guys and they are happy for him to discuss and direct the technician as he works (costs us extra in donuts!). Test drive home and she's mint!
A note about drop links. I ordered standard E46 drop links which should work fine on a standard Z4M from what I found out. However I didn't realised I'd need shorter ones as I have BC BR coilovers fitted. Luckily we had a shorter set of Meyle HD in stock from an old set of KW Coilovers fitted to another Z4. They seem to be about the correct size so will run them for a while and worst case we can swap them for different ones. However no knocks, bangs or odd handling so we should be good for now.
- Front discs.
- EBC Yellowstuff pads
- Meyle HD control arms
- Powerflex front wishbone rear bush (offers additional +0.5° of caster aimed at offering greater precision with improved geometry)
- Inner / outer tie rods - after a bit of research I've managed to figure out Meyle HD parts for a third of the price of OEM.
- Meyle drop links
Before pics:
Meyle HD wishbones
. However a Google of the PN and the word failure brings up a multiple threads on the M3 forums of similar issues all solved by replacing the coupling. So I'm going with that, and 100% not my driving!
