I also have warning lights
Dalek
Highworth, Wiltshire
Z3 2.2i Auto
Every now and again these two lights come on when driving. The performance is not affected and when I restart they go out and everything is OK.
This has happened a couple of times now.
Any ideas?
Maybole , South Ayrshire
Get it plugged in probably one of the sensors is about to fail .
When the light has come on the fault causing it will be logged on the ecu.
When you turn car off as long as when you restart the fault not there the lights go off .
But at some point it wont.
When lights are on traction or abs or both wont work
Sean d
Lincolnshire
I also get them come every now and again, the code reader fault is n/s rear wheel sensor on mine, do you get the ABS buzz on the brake pedal at all,
Ianmc
New Forest
Z3 (M44)
Looks like your car is overdue an inspection and brake fluid change, sensors best replaced at same time likely.:)
Bumpa
Troon
Z3, 2.2 litre Sport
Those are the two lights that are permanently on in my 2.2. According to the handbook the DSC is faulty. The car is safe to drive but the DSC won't work. It has to be fixed before the next MOT in December. Going for diagnosis on Wednesday.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
I've also got the engine warning light on :p
But the garage can't find anything wrong with my Z :)
And she still drive ok ;)
mrscalex
Swindon & Swansea
I find it unlikely there would be no error stored. That's why the light comes on in the first place. Unless there's a faulty connection making the light come on for no reason.
Shelly
Norfolk
The garage put my Z on the diagnostic machine :p
And nothing came up :)
I've got the read out here ;)
But I don't know what it means really :)
I can post a photo if you want :)
Shelly
Norfolk
Here are the photos of my diagnostic test :p
Perhaps @t-tony and @Stevo7682 can have a look for me too :)
roadvoyager1
Shotley Bridge
2.8ltr
As others have said it is most likely a sensor fault which should show up in the stored codes.
Just so that you are aware it can also be caused by the abs control module having a fault. A few of us have had this and it is down to a dry solder joint in the control unit. A new unit is big money, but they can be independently repaired ( or there is a DIY) repair so don't panic if you ar e quoted silly money for a garage fix.
Let us know the outcome of the diagnosis and I am sure we will help you find a sensible fix. Ask for a report showing the stored fault codes and post them so we can understand the issue.
Good luck.
View attachment 67819 View attachment 67820
Hi Shelly the 1st page shows the system check ( highlights several logged faults )
2nd page lists what they all are there could be a number of reasons for each fault thats showing from low battery voltage to electronic glitch to fauty component.
If you haven't had the car diagnosed for a while some of the faults could have been present for a while .
I think personally rather than looking into lots of stuff (now I'm assuming that the car has been driving ok here ) i would get all the fault codes cleared from the memory ( now obviously if you do that and a code wont clear it will need dealt with ) but assuming they all clear run the car a week or 2 and get it plugged back in see what is there then investigate the returned faults .
Stephen.
Shelly
Norfolk
Thank you for your help @Stevo7682 :p
The garage did clear the dashboard for me but within a day the light came back on again :)
Perhaps I'll take the Z back and let them have a look at the Z again :)
You need to get it plugged in again see whats back and thats whats needs looked at
