I also have warning lights
mrscalex
You definitely had errors @Shelly.
And you definitely had an engine error.
And it's highly probable it's the cause of your EML.
The error means the fuel/air mixture is too weak. Typically because there's unmetered air getting in somewhere. I found this list that looks pretty comprehensive to me and saves me using my brain :) :
  • Intake throttle boot
  • PCV system and connections
  • Secondary air one-way valve
  • Intake manifold gaskets
  • Fuel Filter clogged
  • Fuel Pump failure (pressure to low)
  • A faulty MAF
  • An incorrect air filter element
  • A cracked or leaking vacuum line.
Should you be worried? Maybe not. But on the other hand you never know if it's a stitch in time thing. And whether the car may end up letting you down somewhere. I'd probably deal with it. But not on a priority basis.
Get the codes read again Shelly and let's see what has come back.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
Thank you for you replies :p
I'll take the Z back to the garage :)
And see what it reads now ;)
Shelly
Norfolk
Sorry @Dalek :p
For intruding on your thread :)
Hope you got your Z sorted ;)
Merlot
Surrey
E85
I have had no problems for a few months and then these same two lights suddenly light up. Does anyone know of a BMW specialist in the Leatherhead area I can go to? The car drives, stops and sings a delightful tune, so no complaints - but I want the perfect drive I'm used to.
