How to change the Digital clock into Analog clock?
sobe_on
Hi
I have bought the facelift console panel with the analog clock to change my old one but I got the problem and hope anyone can help : (
1. The Uncoded clock have 3 insert but I found 4 wire for the old Digital clock.
2. The function of these 4wires I can check by myself (power/ ground....etc), but the question is I can't check the function for that 3 hold on the analog clock ,
so, any dude can tell me this matter ?
1 = ?
2 = ?
3 = ?
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
Hi Sobe_on,
I imagine that you have solved the problem in the past year:happy: , but just in case somebody else wants to make the same change, here are the answers:
3) the clock connector http://www.realoem.com/bmw/showparts.do ... g=61&fg=15
code. 61136931929
PIN 1 - wire red/ orange
PIN 2 - wire brown
PIN 3 - wire red/ purple
I always found very unappropiate the digital clock on the dashboard of the Z3, a so classic car! Fortunately BMW noticed the failure :pompus: and on the face lift model they changed the digital with analog clock which is much, much better. If you take into consideration that brightness of the digital clock is halved when you turn on the car lights, the digital clock is useless during day light! :grumpy:
I suffered always because of the look of the digital clock but when I have seen on Ebay the armwatch "BMW Z3 Individual", limited edition 5000 units, having the same design with the analog clock Z3, but smaller diameter I start to think to the following project, that I realized last week end: I replaced the digital clock with a hand watch with some hobby labourforce.
Being a little bit lazy :rolleyes: and not willing to spend too much money (for the console, clock OEM, connector) I made a reversible proposal which change the dashboard look and allowed me to read the clock during the day trip. (For eagle eyes has even the calender day number!) .
- a year ago, I bought from Ebay the watch with 20 EUR;
- I made a plastic mould and a fiberglass box for the clock;
- I sanded and adjusted the box to the requested dimensions and sprayed with primer and black mat.
- some safety brackets for the rear side and here it is.......
Do you think it's acceptable or it's more a kitsch?:)
FRANKIE
American Zeds
Hi Sobe_on,
code. 61131383738
PIN 2 - wire brown
WOW!!!!!!!! What a beautiful job!!!!!!!!
Cool job Zeti and just goes to show there is no limit to our abilities and imagination.:scorecard:
2.2 & 3.0 Sport
Brilliant job Zeti, well done. That's a credit to your ingenuity.
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
Thanks guys! :thankyou: "Winter work" when I'm nostalgic for the wheel drive of the Z, but in two months we will be back on the road again!:)
Rudyrov
American Zeds
Phoenix, AZ
2.8 L Roadster
I have long had the same complaints about the digital clock. Thank you for showing me the light!
oldcarman
Canadian Zeds
Pine Falls Manitoba can.
1.9 M44
I can't wait till my car gets here. That was one problem that needed solving that I noted in the pics the seller sent me. Can't figure how a rectangled digital anything got approved for production when everything else is circular. Nice job. JIM
zerolam
i have installed E30 clock into my Z3. Although need a little bit modification the panel, quite happy the outcome.
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
Yes, show it to us!:)
bonbon
Israel
19L Auto
I third that - Zerolam please educate us....
I understand it involves widening the opening in the dash panel to get the bigger E30 clock to fit in the rectangular hole.
oldcarman
Canadian Zeds
1.9 M44
I've bought an Anologue clock in a rectangular housing from a 97 e36 318i SE saloon. I can't wait for it to arrive so I can see how close it is to fitting the hole the digital is occupying now. Can't seen to figure out how to get a pic loaded on my phone but will post one if I figure it out! JIM
bonbon
Israel
19L Auto
Upon inspiration from ZETI - I luckily found a rectangular analog wristwatch which seemed to be a perfect fit to modify an old defective Z3 digital clock '98.
The watch face is 38mm high and 36mm wide (Q&Q Quartz model #VR30J002Y)
eg http://www.skroutz.gr/s/5254010/Q-Q-VR30J002Y.html?keyphrase=vr30j002y
I gutted the digital clock.
I proceeded to rework the front casing to accommodate the watch. (Open the front window and remove ribbing along the inner edges). One can machine it properly or botch it with a file & the help of a soldering iron.
I also removed a notch for the time adjuster knob and added some support inside the barely-modified rear enclosure (only removed a notch for the knob)
Here is the final product. An improvement IMO.
After 7 years I can finally see the time before nightfall :)
BTW - if you cannot find the above mentioned watch - there is another watch that will work Q&Q # VQ92J002Y. It has a 38mmx38mm - although it will only fit into the front fascia and not inside the back - if glued into the front fascia -it can be supported by the ledges in the console.
http://www.amazon.com/Black-Square-Plastic-Unisex-VQ92J002Y/dp/B007TCHG40
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
It looks perfect and much easier to adapt! Congratulations!:)
