Help required Removal of fuel pipes to fuel pump Z3m
Lulubell
Bridgend 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Z3m Coupe
Hi there.
Planning on replacing my fuel pump with Walbro Motorsport 255LPH .
Any idea how the two pipes are removed?
Had a look on many forums google etc but want to double check the correct process as there are many types on the z3 e36
The green clip at the base do you push it in then pull up?
Or push the 90” pipe down then push in the clip inward.
Or put screwdriver behind this green clip then move outward at same time pulling up on 90” pipe.
Or just twist to remove.
Any help would be greatly appreciated as I want to get my ducks in a row to prevent damage before fitting motor this Thursday (if it arrives in time.)
Cheers.
Ady
Pingu
It's not a twist-to-release.
Press down to take the pressure of the locking mechanism, then press the two green buttons together, then gently pull the coupling towards you.
You can get a tool that helps. It looks like a pair of pliers.
bp;ptxus
London
z3M
Hello. I just picked up this old thread because I need to switch out the fuel pump on my 2001 S54. The part number is 16.14.2.229.672. Was that the one you were able to replace? Thank you
Lulubell
Bridgend 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Z3m Coupe
Hi there,
I replaced mine with Walbro Motorsport 255LPH which works great.
Mine is the s50 engine so I don’t know if it’s the same ?
Here is my how to do if it helps..:thumbsup:
bp;ptxus
London
z3M
I think that it is a different part number, sadly, but thank you anyway!
Lulubell
Bridgend 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Z3m Coupe
The part number your end is correct for S54 ..
mine is S50..
Very expensive too..
Give Cotswold Cheltenham BMW as they give discount just say myself a ”M3Cutter off the bmw forum“
Be honest the fuel pump looks very similar to my original which was replaced with Walbro Motorsport 255LPH and gives better pressure sort of upgrade ..
It’s easy to swop this pump out with the Walbro , but follow my instructions , especially make sure the “base of the pump with the filter ” protrudes out on base supporting this pump as high-lighted red in pic! Or will give wrong fuel level’s..
bp;ptxus
London
z3M
I will talk to the mechanic doing the job. Thx so much! Some sh*t drunk smacked into my parked car, and the original mechanic kept my car for so long and never started it up, so the pump seized. It's cost me a lot of money out of pocket - so upset right now. Hope this solution works!
Lulubell
Bridgend 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Z3m Coupe
Sorry to here that bud , some lowlife out there unfortunately!!
Check the relay first as they do fail which mine did !! mine was under the drivers side above the throttle, remove plastic above its in the far right corner green in colour only £18 from the dealer . Or swop out temporarily the horn relay as that’s the same (I described this in my fit list)
bp;ptxus
London
z3M
Hello there. I just wanted to let you know that the garage were able to fit my fuel pump using your instructions, so thank you! I ended up paying less than an OEM part alone would have cost - £586, for part, labour, cleaning of sender and tank, MOT and health-check. New OEM part with discount was £522 plus the other things on top.
ktnez99
West Midlands
Z3 2.8L
Daft question coming up: how do you know when the fuel pump needs changing? Is it that the car won’t start?
bp;ptxus
London
z3M
There might be some fuel in the line, but likely the car will come to a dead halt because no fuel is going through. If its going, you might have rough acceleration, difficulty starting and poor performance..
Lulubell
Bridgend 🏴󠁧󠁢󠁷󠁬󠁳󠁿
Z3m Coupe
I was having a slight misfire on mine changed a lot to fix this problem including the fuel pump but the problem still existed.
In the end it was the DME , had this serviced which totally fixed the issue..
You got to take into account that these Zed’s are approaching 25 years plus!!
These can fail at anytime with the research I did , especially the green relay (My relay had intermittent fault so check this before replacing pump which I didn’t do !! only £18 to replace)
ktnez99
West Midlands
Z3 2.8L
Thanks, @bp;ptxus and @Lulubell
I’ve just got my car back after a far too long a period without it and there are things the matter with it…long story…
