Lulubell
Hi there.
Planning on replacing my fuel pump with Walbro Motorsport 255LPH .
Any idea how the two pipes are removed?
Had a look on many forums google etc but want to double check the correct process as there are many types on the z3 e36
The green clip at the base do you push it in then pull up?
Or push the 90” pipe down then push in the clip inward.
Or put screwdriver behind this green clip then move outward at same time pulling up on 90” pipe.
Or just twist to remove.
Any help would be greatly appreciated as I want to get my ducks in a row to prevent damage before fitting motor this Thursday (if it arrives in time.)
Cheers.
Ady
Cheers.
Ady
