Help Engine won't start make clicking noise.
If you have a charger, put it on charge over night and try it tomorrow. If the dash lights dim or go out when you turn the key to start, then it's likely the battery or connections. If the lights don't dim it's likely starter motor or connections.
ps. Wish I was nearer then I'd come and have a look for you.
mini
No worries tony am on it , if charging battery dont work al get a stsrter , watching a coupke on flee bay from breaker 25 quid , think al be able to change it over myself , got full set bulbs for headlights coming and my wheel spacers for rear too and no where to go !!! Ha
Okay, hope it goes well mate.:)
Ashbandicoot
Passed Away, July 27 2015
Rugby, Warwickshire
I had the same problem a couple of months back, had only popped in to town and was in a loading bay :whistle:
Wasnt sure what was the culprit at the time - bump started and checked voltage before and after, had risen whilst the engine was running so I was assured alternator was good.
Had a gamble and replaced the starter, turned out to be the battery.
At least they should both last a while
Ash
mini
Replaced battery today as my mechanic said , job done starts a treat , wheel spacers delivered and new headlight fog light bulbs too , can't wait to take SEVE for a hurl !!!!!!
Kit
AKA Ken
Illogan,Cornwall
Z4 3.0si Auto
Lidl have very good trickle chargers for about £13 that you can leave on for a long time I think there in stock now
Well saved £40 or so, did get one from Halfords £54 but the Lidl one seemed to good to pass up, so popped in after work and got one and returned the Halfords one.
Thanks for the pointer.
Sir Percival
Redditch
Happened to me today. Turn key....clickety click, no starty.
Just an hour on the charger and it was fine again. Seems like anything less than about 11V and they don't like it.
Good job you lot are here....because I had a bit of a panic to start with as I am taking it for service and tune in the morning :nailbiting:
Low Rider
no point battery will just go dead again if broke
better looking at replacement battery
just remember to find radio code before changing or use jump leads to do the change over
I would agree new battery
A code saver is one option. All you need is a plug for a cig. lighter with a length of twin core cables with croc clips on the ends with an inline fuse in the pos. lead. Plug into cig. lighter socket and connect leads to a battery observing polarity of connections. You can safely remove the battery from the boot without losing codes.
BeemerBoyo
Hartlepool
Z3 (E37 facelift) 2.2 Sport Roadster
Having exactly same issues, car been in storage since October but I start it up every 2 weeks. It's on a trickle charger and said battery full. However last time only barely started, now clickety click. Disconnected and reconnected charger, rocked back and forth in gear, tried again and JUST caught and started. Pretty sure it's the battery as it was on 6 years ago when bought car and its not original BMW. Will report back with findings.
Sounds like the battery is past it's sell by date.
