It looks as though the pulley is bent from your photo, I definitely wouldn't even start it like that.
Real OEM is a good source of diagrams, this page shows the engine.
http://www.realoem.com/bmw/enUS/partgrp?id=CL32-EUR-02-2000-Z3-BMW-Z3_20&mg=11
If you enter the last seven letters of your vin number on the first page it will go to the correct parts for your car. Sopers of Lincoln are are very helpful and give a discount.
https://zroadster.org/threads/welcome-to-soper-of-lincoln-bmw-parts.3137/.
The fan coupling is held on with a 32MM nut which has a LH thread, you need to somehow jam the pulley and give the spanner a sharp tap in the clockwise direction. There are tools for holding it but I have always manged to jam it with a large screwdriver.
Yours does look a bit corroded.
You will need to remove the shroud with the fan but that is just two plastic fasteners at the top.
