H&R ARB's won't adjust to the inner (harder) setting (front & rear)
Stormy_be
Belgian Zeds
Belgium, ieper
Z3 2.8 Roadster
I suppose you can use those on both settings as the head can turn.
The diagram also shows the head should be straight.
This will not be the case....that the reason why the normal one does fit, right.
After looking a second time.
At the bottom it would only use half of the mounting bracket.
Don't think that is a good idea.
It's better like it is, going thru and thru.
PeterJ
Hong Kong Zeds
Hong Kong
Z3 2.8 Roadster M52B28
the standard head would not turn enough and would hit the metal frame below. Anyway , I will keep them on the outer settings for a while now I have the B6's fitted
Stormy_be
Belgian Zeds
Belgium, ieper
Z3 2.8 Roadster
Strange that they sell it as an 2 point ARB and that you need to change parts and connection points to get it in the second position.
PeterJ
Hong Kong Zeds
Hong Kong
agree! they should explain more clearly
