For the Love of my Zed! Novice vs Car
Mazza
Bognor Regis
I think this similar to a fix I saw on Wheeler Dealers, but I cant remember what car it was done on.
The existing window rubber is a hollow tube, and the idea is to push a smaller dia tube or solid rubber down inside it. This stiffens and reshapes the existing window rubber.
May even work using polythene tubing??
ZedHead
Prefacelift 2.8i
Finished installing front hubs, new brake lines with joint, brakes, & disks. Only problem the non oem speed sensor doesn’t seem to fit and its been a mission pushing it almost home. Turned on car and found a few lights on the dash. Haven’t topped up coolant and so didn’t want to start her just yet. Also found that although I’ve got the radiator temp sensor fitting I don’t seem to have the right fuses in leading to a question around the possibility of a fan delete.
ZedHead
Prefacelift 2.8i
The inner wheel stuff is looking smart, and the gearknob came today . . . Sweet! The 6 gear will be returned.
ZedHead
Prefacelift 2.8i
After closer inspection i may have found both the radiator temp switch and aux fan plug! Need to obtain a few fuses get a temp switch and do the kettle test with a voltmeter. What could go wrong?:nurse::nailbiting:
ZedHead
Prefacelift 2.8i
Wheels went back on today and she’s now sitting pretty!
Looking good now mate :thumbsup:
ZedHead
Prefacelift 2.8i
Took her out for a local drive to start breaking in the brake pads and disks, all abs lights cleared themselves once I got driving and it’s all feeling tight with all that power flex in there:ymdevil:
Jack Ratt
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
Looking good
Mazza
Bognor Regis
Great stuff ......and you deserve the ‘ fuel additive’ after all that work
Mazza
Bognor Regis
What does fuel additive do #googlesearch
In the case of Punk IPA.........after enough of them my legs cant take the my weight, so I fall over. =))
MRH1966
Lewes, East Sussex
1.9 M43 , 2.8 auto & 2.0l
I have been watching this thread with great interest. Well done you have done a great job.........We are just down the road in Lewes...........if you ever need anything or want to plug your car into INPA........give us a shout..
ZedHead
Prefacelift 2.8i
@MRH1966 thanks for the offer and compliment! When you say if you need anything...how far do your skills go? I will at some point need help with a manifold swap but this will be in the new year once I’ve colllected all the required parts! As for the INPA (had to google that) not sure what I’d need from it as my OBD2 reader is coming back with 0 faults, nice! Great to have support from another Zed family member
