Jobs currently completed:
Installed BC BR coil overs and reinforcements plates, upgraded speakers to 6” footwells, 13cm behind seat. Also had to carry out a mod to the headlight/parking light switch as it failed, seat bushes.
Besides from the subframe and brake lines there is a coolant leak I’m worried about, seems my entire coolant has drained out! The drivers seat has confused the hell out of me as the forward back switch doesn’t seem to function and i had to wire from the passenger seat to adjust. When i checked the voltage at the connection when pressing the seat button it showed 12V so no idea why this isn’t working, only know this is a failure with regards to an MOT. So once the subframe & brakelines are done I’m ghoing to need some help with the:
1 - Coolant issue
2 - seat switch issue
Another issue i have which may be reasonable normal is the gearbox show signs of oil around the area it attaches to the prop shaft. Not sure if an easy service of seals is within my capabilities (ie getting the gearbox off and changing the clutch which is also squeaky).
Phew, so, it’s always been a dream to learn a car and to be able to do some of these things and by golly did i get the lemon to learn on. Just hope the engine is still good with that coolant leak?!
