Maybe one to watch? Blaze channel @ 9:00pm (VirginMedia Ch 216)
Which Knobs is that then??I wouldn’t watch that. Some right knobs in that episode![]()
How was the episode as a whole? I’ve not had any involvement with the rest of the episode.Just turned it on and spotted @Lee![]()
Looked like he was at @spurs fan in a coupe's house with all them Z3's and spotted @Rha's coupe in the background![]()
I watched it last night on catch up, and thought the same thing....does the rear hub come out that easily?Good watch. Spotted some familiar people.
Are the rear wheel bearings that easy to remove?
Yeah I didn’t find it to difficult. Last set I did was Paul’s. I used a long threaded bar through the middle with a plate on the back and wound it back on.@Lee ,
Took these pictures from the show, to show how they removed the hub from bearings. Once off, the backplate is accessible which is great.......but what about replacing it after new back plate installed. They didnt show that bit ! How do you push them back on? How difficult is that?
A long bar that has an external thread the bar goes through the middle then on the back I have a plate with a nut to stop it coming through. Slide the hub over the threaded bar with another plate and nut and wind it tight. This in turn presses the hub back on.Sorry Lee, being a bit thick......just to clarify.....external threaded bar ....with an internal thread one end that screws on to the stub axle where the retaining nut goes ??
I haven't watched the whole episode yet, got it set for record as it's repeated at 7am tomorrow. Would like to see how easy the rear bearings are to remove as I think my drivers side one needs changing.How was the episode as a whole? I’ve not had any involvement with the rest of the episode.
