I've got the exhaust, heat shields and propshaft off tonight. So tomorrow I'll be dropping the gearbox.
Obviously part of this process involves letting the engine and gearbox lean backwards as a jack is let-down under the gearbox. So I'm wondering what's sensible to disconnect in the engine bay that might get damaged as the engine goes back. So probably anything that is connected to the engine bay at one end and won't move as one.
The airbox has to come out anyway so I'll do that. But I'm looking at the aircon pipe and wondering what's going to happen to that unless I disconnect it from the compressor? Has anyone done a clutch on an air con car to advise?
I've found some notes from @NZ00Z3 on checking the condition of the DMF - https://zroadster.org/threads/dual-mass-flywheel.42215/#post-633363. Thanks. Very useful.
I really don't want to fork out £300 routinely for a DMF unless I have to. But I wondered what the wisdom is on doing this anyway while the clutch is out. The car has only done 72k.
