What would be the downsides of chasing to thicker oil, or the other options ( I assume cost mainly on the other two )
I wish it was that simple turned out alot more serious than that. I actually did have this problem when my Z3 was a 2.2, it was a dry soldered joint in my binicle.Didn’t @Lee have this with a ///M in the shed and it turned out the tick over was below the recommended minimum.
Wasn't sure what the binicle was - is this in the cluster? And related to Steering lock triggering red oil light, or the red light in general at warm idle?think you probably need to look to Lee’s advice on the cluster if other roads are exhausted.
Binicle=cluster. Comes out with 2 upside down screws under the top of the pod behind steering wheel. 3 wiring connections to disengage. Push release pin in. Swing arm. Don’t force.Wasn't sure what the binicle was - is this in the cluster? And related to Steering lock triggering red oil light, or the red light in general at warm idle?
@mrscalex The thing is, if the cluster issue causes the oil pressure lamp to come on when steering is at full lock, it sounds like a bit of a messy job for a gain I wont notice. I guess my acrobatic parking manoeuvres are generally at cold idle so it never appears.I wish it was that simple turned out alot more serious than that.
That’s my two pennies worth on repairing the cluster. As you’re doing now, the right thing is to compare notes with Lee before sending it for repair. I can’t answer that bit for sure.@Lee what was the more serious issue, the suspense leaves me in dread.....
If the cluster is the cause of the warm idle issue more generally, such as when I'm in neutral at the lights or in traffic, then for the piece of mind I'm not killing the engine by normal driving then that would motivate me to fix the cluster.
I’ve never had an engine knock myself. But only today I was reading something that suggested a small misfire on an M54 can sound like knocking. In that particular case it was a leaking rocker gasket that had spoilt a plug. I’d be more inclined to believe the garage had introduced a misfire than damaged the engine from an oil change.@Lee the context is the light is coming on at warm idle which the cluster dial is telling me ~650-750rpm.
The light will then go off at about ~900-1,000 rpm if I touch the throttle (again from the cluster).
It hasn't had a flush, but the garage did put new oil and filter. I suspect the latter two have not been done properly or enough which is causing the knocks.
I'll see if they can check the revs via diagnostics, as it's still with them. Could be a shout as I was having a sticky rev counter at one point. I think someone else had suggested idle might be too low.
I also thought that could be a possibility too.I’ve never had an engine knock myself. But only today I was reading something that suggested a small misfire on an M54 can sound like knocking. In that particular case it was a leaking rocker gasket that had spoilt a plug. I’d be more inclined to believe the garage had introduced a misfire than damaged the engine from an oil change.
