- Joined
- Nov 25, 2012
- Points
- 178
- Location
- Newport, South Wales,UK
- Model of Z
- Z3 M43 1.8 (1999) and Z4 E85 2.5 (2003)
Did you pump the smoke into the boot with the throttle open so the smoke has a free flow through the engine, I use a foot pump attached to my smoker using baby oil on a wick surrounded by resistance wire connected to 12v, the air pump produces enough smoke flow to get through the engine and find any leaks. If you are certain you have no leaks then time to look at the exhaust sensors, can you see what they are performing like using live diagnostics, pre cat should be producing a wave form as the voltage ranges up and down if they are working ok. Last thing would be the Maf, if thats duff it dosn't set codes but upsets other sensors and can lead you in the wrong direction.
If you take the exhaust sensors out you need to get under the car and make sure its supported with good axle stands. I find a ring spanner on them worked better than the sensor removal sockets.
