I also prefer the look with the handle lower down. I'd like to set mine even a bit lower than yours. I'll probably fail but I want to try.
What color is your gel coat? (What RAL)
Did you by any chance take a photo of your cut out on the Zed door - and that bracket to the plunger? In fact anything to indicate where your cutout is on a zed door and what your bracket is attached to?I wanted to sit them slightly lower than others have so needed to make adjustments to the cut out on the zed door and fix a bracket to the plunger on the handle. Could have opted for mgb or triumph handles but preferred the look of the mini
Thanks Steve,Dunc
I had originally thought of mgb ones as they're relatively cheap brand new and no key to worry about......not that I'm using the key on my mini ones. I just prefer the feel and shape of the mini ones.
Pic of an mgb one for reference.
I used self adhesive felt pads on the pivot plate to soften the sound of metal on metal when opening the door. Think I got them in b and q (floor protectors for furniture feet).
Cheers
Steve
Those handles are Alfa Romeo as these were what Chris had intended to use. I spent weeks trying to get them to work but to no avail.Thanks Steve,
I saw on one of tribute's pages this kit. Is this the one you got from Chris?
Those door handles are very low. What mechanism of L brackets or whatever did Chris use to get them that low? I don't want mine that low but would be interested in knowing how that was done.
BTW. That blue door with the MGB handle. Are they a forum member? Any links to pics of their car?
Thanks
Ian
Those handles are very low. Could you say what the method was for connecting them up?Those handles are Alfa Romeo as these were what Chris had intended to use. I spent weeks trying to get them to work but to no avail.
Looked great but I lost the will to live with them![]()
It was interconnecting levers.Those handles are very low. Could you say what the method was for connecting them up?
Thanks. Interconnecting levers. No. Not going there.It was interconnecting levers.
